454/365 question >
454/365 question
454/365 question
Old 01-10-2006 | 10:11 AM
ctadams21's Avatar
Default 454/365 question
Do the 365hp 454s have forged pistons? Roller cam?
Thanks,
Clayton
ctadams21 is offline
Old 01-10-2006 | 10:20 AM
Pat McPherson's Avatar
Default Re: 454/365 question
Forged pistons yes.
Roller cam in Gen VI engines, 1996 and newer.
Patrick
Pat McPherson is offline
Old 01-10-2006 | 12:46 PM
KAAMA's Avatar
The Merc 454cid/365hp engine came with the very crude stamped steel rocker arms, but it does have all forged parts---crank, 7/16" rods, and pistons including a 4-bolt main block, and rectangle port heads. I don't know up to what year that Merc produced the 454cid/365hp engine, but when it first came out in the mid to late 80's it came with a flat tappet hydraulic camshaft.
KAAMA is offline
Old 01-10-2006 | 02:44 PM
ctadams21's Avatar
Thanks guys. Just wondering if these engines were a good candidate for 525sc conversion. Sounds like they would be o.k. with a cam change and maybe some roller rocker arms, and the blowers of course.
Later,
Clayton
Old 01-10-2006 | 03:20 PM
A Merc 525SC is/was basically the 454Mag with a supercharger.
Dished pistons, Crane cam, and roller rockers are among the differences.
Patrick
Old 01-10-2006 | 03:29 PM
Might be worth a set of low compression pistons if you're doing a rebuild.
The 525SC CR is only 7.5:1.
Gary Anderson is offline
Old 01-10-2006 | 04:44 PM
CMG's Avatar
CMG
had a set in old boat, good motors
Chris G.
CMG is offline
Old 01-10-2006 | 05:43 PM
KAAMA's Avatar
Originally Posted by ctadams21
Thanks guys. Just wondering if these engines were a good candidate for 525sc conversion. Sounds like they would be o.k. with a cam change and maybe some roller rocker arms, and the blowers of course. Clayton
Clay, I would say "yes" to your question. On the reliability side, I would at least add some roller rocker arms, ARP rod bolts, hydraulic roller cam/morel lifters, and a good set of pistons designed for supercharging---heck, the pistons you have may even be okay to use for supercharging, but if you want to be top notch I would consider new pistons. I would also and have the engine(s) balanced.
Just make sure you have a precision machine shop who is known well for their machine work and good reputation----a shop that is very familiar with clearances needed to make an engine survive in the marine performance world.
"rmbuilder" (Bob Madara)is a good man to contact for valve train components, and very helpful when it comes to cam selection. Have fun with your project.
KAAMA is offline
Old 01-10-2006 | 06:47 PM
ctadams21's Avatar
Thanks guys!
Old 01-11-2006 | 01:45 PM
Big Block Billy's Avatar
Smile Re: 454/365 question
365 motor has Trw L2399 forged pistons. I believe .095 dome. BBB
Big Block Billy is offline
smokin' gun
Wanted
5
07-22-2008 04:11 PM
MILD THUNDER
Northern Illinois Offshore Club
5
06-09-2008 09:28 PM
QUIKDECISION
6
02-21-2005 07:00 PM
nobudget
6
03-27-2002 01:15 AM
