Fuel Pressure Gage >
Fuel Pressure Gage
Fuel Pressure Gage
Old 01-12-2006 | 01:27 PM
Rage's Avatar
Default Fuel Pressure Gage
Where and how is the best way to instal an analoge fuel pressure gage on a 2005 496HO with the Merc 'Cool Fuel' system?
Rage is offline
Old 01-12-2006 | 02:12 PM
Default Re: Fuel Pressure Gage
assuming mpi like mine, the fuel rail has a test port in the front of it that you can tap larger and put your fitting into.
you want to be measuring right there at the rail... nowhere else...
and IF you are using a mechanical gage you want to run a -3 aeroquip line rather than the teflon... but i rec a 12 " long aeroquip line to an ELECTRIC sensor and then wires forward to the gage. you don't want the sensor screwed straight into the rail as this subjects it to all the vibrations and stresses on a threaded fitting... just asking to fail and light you on fire.
at the end of a short line ( or as long as you want) it isolates the sensor from all that and it last a LOT longer .. and maybe won't crispy critter you someday.
stevesxm is offline
Old 01-12-2006 | 02:43 PM
Rage's Avatar
Originally Posted by stevesxm
assuming mpi like mine, the fuel rail has a test port in the front of it that you can tab larger and put your fitting into.
Perfect!
Rage is offline
Mikey Likes It
4
03-06-2007 02:15 AM
Nordicflame
2
04-13-2005 12:35 PM
Zanie
5
03-10-2005 10:58 AM
BUSTNOUT
08-17-2003 09:54 AM
Aces & Eights
2
07-01-2003 10:05 PM
