Pulling Motors ... >
Pulling Motors ...
Pulling Motors ...
Old 01-21-2006 | 09:39 AM
bobbarker's Avatar
Cool Re: Pulling Motors ...
Clean up or paint the bilge while your at it.
bobbarker is offline
Old 01-21-2006 | 10:12 AM
Default Re: Pulling Motors ...
I will tell you what I forget. The rear motor mounts, remember how the fiber washer and lockwasher are placed. They must be exact when you put it back together or your alignement will be off.
I always have to look in a manual or search from previous postings
When I first starting going this, I also used masking tape on the wires, wrote a number on it then wrote down exactly what the wire went to. I am getting much older now and forget even after doing this so many times
1BIGJIM is offline
Old 01-21-2006 | 10:19 AM
On the rear mounts...if you take some trim adhesive and glue the leather washer down....it tends to hold the spring washer in place,make sure the aluminum nuts are in place
flash32118 is offline
Old 01-21-2006 | 10:50 AM
formula31's Avatar
If this is Bravo's, Check the springs, they are usually cracked. And it the rear bolts come out hard, you might want to replace them or at least the nuts.
formula31 is offline
Old 01-21-2006 | 11:07 AM
Rig something strong to lift the hatch off and fine a place to store.You should be able to disconect the rubber hose of the exhaust to tips,if not take the risers off.We keep different colors of tape so if we have to cut a wire ,we put tape on it and cut through the tape and match the colors going back. Get-er done its getting late.
Dixie Doug is offline
Old 01-21-2006 | 11:55 AM
offthefront's Avatar
great Stuff Guys .... keep it comin ...yea the plan is to paint the bilge and do some re-rigging .....I have seen some motors with the Wiring harnesses come from the transome area instead of accross the front of the motors .... I assume you can get different length Harnesses ? Port motor has new harness going to move it to starboard side nad get a longer on for port motor ... The hatch is coming off and stored away ...
offthefront is offline
Old 01-21-2006 | 12:41 PM
formula31's Avatar
Same year as my old one. Look at the hatch hinges, mine were crap. I made new ones out of SS.
302Sport
09-19-2008 01:19 PM
Boomer35
02-07-2008 07:45 PM
Gunrunner72
3
07-10-2007 10:28 AM
32 thunder
07-09-2005 10:09 AM
THRILLSEEKER
Cigarette
2
07-12-2002 02:02 PM
