Dual Batt isolators... >
Old 02-07-2006 | 03:01 PM
Default Dual Batt isolators...
I have a dual batt setup and was debating on getting an isolator. Is it really worth getting one? I tend to do a lot of parking with the radio on and tend to drain the house battery regularly.
synack is offline
Old 02-08-2006 | 03:24 AM
Default Re: Dual Batt isolators...
The advantage of having the isolator is you charge both batteries at the same time whenever you are running. No need to remember to change the switch for charging. The drawback to the isolator setup is the voltage drop across the isolator rectifier means longer charge times for either battery.
NightHawk is offline
txriverrat2001
3
10-10-2007 11:32 AM
t500hps
01-30-2007 10:11 PM
synack
4
06-05-2006 05:47 PM
Scott
16
05-31-2003 01:04 AM
Biggus
10-12-2002 11:22 AM
