Merc500EFI/500Buldog >
Old 02-15-2006 | 11:16 AM
Default Merc500EFI/500Buldog
I would like to what is the difference between a 500 EFI and the 500 Bulldog, to what I know both as 470HP and what else?
mars is offline
Old 02-15-2006 | 11:31 AM
Von Bongo's Avatar
Default Re: Merc500EFI/500Buldog
The Bulldog is a 540 Ci the 500 efi is a 502.
The bulldog is blueprinted and balanced the 500 efi is not.
The bulldog is N/A and the 500 is EFI.
The bulldog is a great motor, so is the 500 EFI just go about making 470 HO different.
Von Bongo is offline
Old 02-15-2006 | 02:15 PM
Do you know if in 2001 both of them were Closed Cooling ?
mars is offline
Old 02-15-2006 | 02:19 PM
Neither one was ever closed cooling
JaayTeee is offline
Old 02-15-2006 | 04:35 PM
outdrive man's Avatar
you might be thinking of the 525efi which is closed cooled.
outdrive man is offline
Old 02-15-2006 | 11:27 PM
Bulldog's also had manley rod's, lunati crank, 500efi's are gm rods and crank.
RonS is offline
Old 02-16-2006 | 12:03 PM
Canada Jeff's Avatar
The hp500efi makes 500 HP. 470 Prop Shaft HP.
For what its worth.
Canada Jeff is offline
Old 02-16-2006 | 12:09 PM
Since no one mentioned it, The bulldog was a tall deck block, the 500 EFI is a standard deck.
Gary
rdoactive is offline
Old 02-16-2006 | 02:07 PM
BajaRunner's Avatar
why build a 540 with better parts with the same hp?
BajaRunner is offline
Old 02-16-2006 | 05:04 PM
3 things I can think of.
1. The limitations of the Bravo One drive.
2. Wouldn't want to trump the 600SC
3. Mercury overbought HP465 cams from crane,
and needed to get rid of them
JaayTeee is offline
