-   -   ??? Replacement of Trim tab indicator cable (https://www.offshoreonly.com/forums/general-q/122756-replacement-trim-tab-indicator-cable.html)
t500hps 02-16-2006 08:00 PM
3 Attachment(s)
I need to relace one of my cables. I've re3cieved the relacement Red 33C supreme in the proper length, but not sure how to disconnect it from the helm.
Can I remove the plate from the back so that I can more easily access the unit from the front of the dash? pics to follow:
GOODT 02-16-2006 08:03 PM
Re: ??? Replacement of Trim tab indicator cable
yes but take it very slow and carefull the indicators are spring loaded and if not carefull WILL fly all over have replaced many cables.....
oh and FYI if you loose one of the indicator springs the spring from a pen works great!!!!!!
t500hps 02-16-2006 08:21 PM
Thanks for the heads up.....I stuck the camera in the dash to take the pics, I can see even less of what I'm working on than the pic shows. When the rear plate comes off are the springs likely to spring or just if you move the display around too much? Should install the new from the tab end or at the indicator end first?
GOODT 02-16-2006 08:34 PM
Use old cable as a fish disconect at transom pull into engine compartment then tape the two together and pull from front make shure you cut any wire ties first and pull toward bow
Strip Poker 388 02-17-2006 01:24 AM
post 26 . I just did the same thing
http://www.offshoreonly.com/forums/s...ghlight=cables
Linster 02-17-2006 03:22 AM
I see the main problem, there are not any beer cans in the way.
GOODT 02-17-2006 05:35 AM
great how to thread... kind of "THIS OLD BOAT" but wheres Bob Villa????
GOOD JOB
t500hps 02-17-2006 05:37 AM
What the hell are you ding on here at 4:30 am?
Since your the man with the beer frig, I'll bring the boat over in a few days so you can help get this knocked out :D
Strip Poker 388 02-17-2006 08:34 AM
Damm Linnie you got up about the time I went to bed :evilb:
