Prop shaft adaptors >
Prop shaft adaptors
Prop shaft adaptors
Old 02-25-2006 | 11:33 AM
Big Block Billy's Avatar
Post Prop shaft adaptors
What do you guys think about these ? maybe help keep a shaft from twisting ? BBB
Big Block Billy is offline
Old 02-25-2006 | 12:06 PM
GOODT's Avatar
Default Re: Prop shaft adaptors
never seen it before maybe to convert a bravo to accept xz/xr prop
GOODT is offline
Old 02-25-2006 | 02:29 PM
Yes that is what I think, but will it make a stock shaft less prone to twisting, ? Notice it's fully splined in and out. BBB
Old 02-25-2006 | 02:31 PM
GOODT's Avatar
would think the opposite less material....like the outer shaft on a bravo 3
GOODT is offline
Old 02-25-2006 | 02:52 PM
A bravo 3 outer shaft isn't splined on the inside. Every Bravo/Trs/ Alpha that I have with a twisted prop shaft is in the spline area. Usually in the middle of the splines. Very rare on alpha it usually blows the pinion gear first. I would think that putting this between the prop and shaft also using the XZ solid Flotorque adapter would substantialy reinforce the shaft. Unless there is a fully splined adapter or prop hub that would fully distribute the load on the propshaft. Just my 2cts. BBB
Old 05-19-2013 | 09:28 AM
who makes them?
pinball is offline
Old 05-20-2013 | 01:33 AM
Even if it does keep the prop shift from twisting, I think all that will probably happen is the lower vertical shaft splines will twist instead.
Griff is offline
JMPH
11
05-23-2005 12:12 PM
Tantrum
Prop Talk
5
04-26-2005 11:12 AM
EWB
1
12-19-2002 08:10 AM
MIKEHTMSR24
07-22-2002 03:18 PM
MIKEHTMSR24
0
07-22-2002 01:40 PM
