Check computer hrs on 525's >
Old 02-25-2006 | 07:25 PM
Question Check computer hrs on 525's
How do you check the hrs on the computer on 525's. Will a handheld NAPA engine code reader pull that info? Do I need special software for my laptop? if that is required???
382 newbie is offline
Old 02-25-2006 | 07:29 PM
GOODT's Avatar
Default Re: Check computer hrs on 525's
no an obdII reader wont pull them( napa code reader) you need either the merc handheld reader, the spx merc comp program and adapters, or the rinda comp program and adapters
GOODT is offline
Old 02-25-2006 | 07:58 PM
offthefront's Avatar
Can the history be reset ? Like a set of 502 EFI's ...should it have total hours ? Also the # of hours at certain RPM ? Seems I heard when you scan em it resets everything .... m
offthefront is offline
I use the Rinda tester for Merc, Volvo and Crusader. I have a special adaptor for SmartCraft.
Edward R. Cozzi is offline
Old 02-25-2006 | 08:08 PM
GOODT's Avatar
I have both the rinda comp program and the spx merc progam
the hist can be reset but not the total hrs
in other words no you cant " roll the odometer"
GOODT is offline
Old 02-26-2006 | 08:10 AM
gsmith9898's Avatar
if you change the ecm than you change the hours don't you?
gsmith9898 is offline
Old 02-26-2006 | 08:22 AM
GOODT's Avatar
yes it starts at what ever the comp has stored on it prom(programable read only memory)... then theres eprom (erasable)ie history
GOODT is offline
docmanrich37
4
03-14-2007 04:22 PM
JJONES
2
05-08-2006 11:48 PM
Waterfoul
12-05-2004 01:18 AM
mmo jo
03-01-2003 07:26 AM
turbo2256
5
04-26-2002 09:30 PM
