Motor head guys - need some help on a timing question >
Old 02-28-2006 | 05:02 PM
  #31
formula31's Avatar
Default Re: Motor head guys - need some help on a timing question
Yea, if the cam timing is way off there could be low low cranking compression.
formula31 is offline
Old 02-28-2006 | 05:47 PM
  #32
Originally Posted by Dave_N
You can have zero leak down and low compression if you have a flat cam lobe or collapsed lifter that only allow the intake valve to open very briefly and will not allow much air into the cylinder to be compressed. Then you would have low cranking compression in the cylinder, but could still have zero leak down.
Dave
Same thing I was thinking. Wiped out an intake cam lobe.
Griff is offline
Old 02-28-2006 | 08:23 PM
  #33
GOODT's Avatar
sorry all, I read it as 80 lbs comm but leak down held 0 lbs
GOODT is offline
Shah Mat
0
06-19-2007 11:18 AM
BobbyB
9
06-21-2006 01:24 PM
ghittner
9
02-20-2006 07:58 PM
37Talon
11
12-04-2005 10:07 AM
LPA2106
03-18-2004 11:28 PM
