which hvh carb spacer do i need >
Old 02-28-2006 | 02:22 PM
BajaRunner's Avatar
Default which hvh carb spacer do i need
There are a couple on here. I want a 1" carb spacer for my 2000 hp500 carb'd engines. which one do i get??
http://www.cfm-tech.com/catalog/carb...1_products.htm
BajaRunner is offline
Old 02-28-2006 | 02:25 PM
Default Re: which hvh carb spacer do i need
Ss4150-1a
cstraub is offline
Old 02-28-2006 | 02:45 PM
Yep, first one on the page.
Griff is offline
Old 02-28-2006 | 02:46 PM
BajaRunner's Avatar
awesome, got em coming.
thanks!
Old 02-28-2006 | 06:26 PM
baja36ft's Avatar
I Use The 2 Inch Spacer.
baja36ft is offline
Old 02-28-2006 | 07:23 PM
boatn70's Avatar
what'd you see with the 2" and on what engine? im considering the spacer in the near future too.
boatn70 is offline
Old 02-28-2006 | 09:11 PM
BajaRunner's Avatar
stan,
did you have to adapt your fuel lines or did they stretch?
Old 03-01-2006 | 10:05 AM
Wobble's Avatar
SORE MEMBER
More spacer isn't necessarily a good thing. I'd go with cstraub's recommendation.
Personally I won't change anything on my intake system on a boat motor unless I'm doing it on a dyno. You never know what changes are a plus and which ones call for a jetting change.
You may want to contact cfm-tech as he has made many pulls with various combinations and can tell you what to look for.
Wobble is offline
Old 03-01-2006 | 10:52 AM
TC's Avatar
TC
What about the thermal barrier properties of the phenolic material? Is the transfer of heat in a marine engine compartment not as much of an issue as in automotive? I have used a 1" Mr. Gasket phenolic spacer for many years and thought that the thermal barrier it provided between the intake and carb was probably as much of a gain as the extra air flow and signal it may have provided. I realize and fully agree that they are mainly a tuning tool but what about the heat?? I plan to purchase a new tapered/blended spacer but am still unsure as to which direction to go.....Canton, HVH ,Wilson and others. Any comments? Please!!
TC is offline
Old 03-02-2006 | 05:51 AM
where can you purchase fuel line adaptors for a 500hp
500hps is offline
