water heater >
water heater
water heater
Old 03-02-2006 | 08:18 PM
Default water heater
does anyone use a flow through water heater from EEMAX Inc, like model EX2412.
Get the water hot enough for a comfortable shower?
thanks
AM
amarek is offline
Old 03-14-2006 | 08:31 PM
Default Re: water heater
thanks
AM
Hello out there, does no one has a flow though water heater?
thanks
amarek is offline
Old 03-14-2006 | 09:05 PM
t500hps's Avatar
21 and 42 footers
Don't know what models I had on previous express cruisers but the heat exchanger in the water heater produced water hot enough to burn you. If you looking at something like a 6 gallon tank that has engine cooling water run through it before it is discharges then you'll be good. Only takes 10-15 minutes to heat the water up too.
t500hps is offline
dave-01
Baja
3
11-21-2007 02:09 PM
