Can a 572ci make 850hp na? under 6000rpm
#51
Re: Can a 572ci make 850hp na? under 6000rpm
Originally Posted by gg10
582cid 4.625bore, 4.375 stroke, static cr 10.75, dart 335 heads, edelebrock victor worked over by wilson, single blp 2.125 dominator, crane hr made 850 @ 6000 on chevron 92.
#52
#53
jdnca1 idle was very nice loaded on the dyno 550-580 never stalled once
no load 750 - 800 best part is the idle sound hope this shakes things up this is about 65 -70 more hp then the way we had it set up not to mention the fuel derlivery problems from them holley pumps we had.
#54
Kamma, I am a hobbist with these boat motors, the more knowledge I get the more I realize that most engines are over kill on cyclinder head , this engine which I dynoed last week has taught me alot about this in the low rpm band I run it in. also it is actually 588" I was incorrect in my eariler post.gg
#56
Kamma, I am a hobbist with these boat motors, the more knowledge I get the more I realize that most engines are over kill on cyclinder head...gg
Anyway, I'm sure you have gotten some raised eyebrows for wanting to run a 335cc head on a 588cid engine. I'm running 315cc AFR CNC ported heads on a pair of 565cid engines. I cruise at right around 3200-3500rpm in a 32' Active Thunder.
#57
Sonic, If you drop static to 9 ,you should change cam so I would be guessing at hp around 775. Kaama , I did a 555" for a friend, 4.56x4.25, I used a pair of 325 heads I had and a dart intake, the hp/cid was down, to much head , valve and intake for the low rpm in these boats. gg
#59
850hp 572 = 1.486hp per cid.
350 x 1.49 = 521.5
383 x 1.49 = 570.67
406 x 1.49 = 604.94
454 x 1.49 = 676.46
502 x 1.49 = 747.98
540 x 1.49 = 804.60
565 x 1.49 = 841.85
The question was by 6000rpm right ?
350 x 1.49 = 521.5
383 x 1.49 = 570.67
406 x 1.49 = 604.94
454 x 1.49 = 676.46
502 x 1.49 = 747.98
540 x 1.49 = 804.60
565 x 1.49 = 841.85
