1999 Formula Silent Thunder? >
Old 03-05-2006 | 05:28 PM
Thumbs down 1999 Formula Silent Thunder?
How do you remove the silent thunder off of the rear of a boat? I am trying to take mine off as it is broken and I need to fix it? Thanks.
studstud1 is offline
Old 03-05-2006 | 06:24 PM
Pwrbt33's Avatar
Talking Re: 1999 Formula Silent Thunder?
From what I remember when I took them off is they are only through bolted onto the transom. The tips are on the transom, and there is a black seal around it. The swim platform should be cut out around the tips. That should be it. If you got all the bolts out it should only be stuck on there via the seal.
Good luck. Keep us posted.
John S.
Pwrbt33 is offline
Old 03-05-2006 | 07:20 PM
t500hps's Avatar
21 and 42 footers
Default Re: 1999 Formula Silent Thunder?
Several recent threads about removal. Do a search in the Formula forums.
t500hps is offline
CelticPride
5
03-20-2023 12:23 AM
farmermoe64
11
12-04-2007 03:24 PM
HiredGun57
2
10-08-2007 01:47 PM
hot n hazy 2
09-15-2007 05:57 PM
zelinsm
1
04-23-2004 07:43 PM
