Alpha 1 Water Pump >
Alpha 1 Water Pump
Alpha 1 Water Pump
Old 03-09-2006 | 08:07 AM
Default Re: Alpha 1 Water Pump
regarding the disconnect and plugging of the alpha hose - would there be a problem with just teeing it into the transom pick-up line and running both pumps? It would seem to be a nice back-up should one ever get plugged, and also still keep the outdrive cool?
wat2c is offline
Old 03-10-2006 | 08:40 AM
I used a Johnson crank mount pump(same as Jabsco)
the big block version ( full port )with a thru hull pickup.
I installed a fitting above the drive and use the pump in
the drive as a drive shower.
Daddio
I also installed Shurflow sea strainer ( plastic cheapy)
Daddio is offline
boomer
05-02-2006 05:09 PM
pullmytrigger
7
11-27-2005 09:29 PM
Iggy
5
04-18-2004 08:34 AM
makomagnet
14
12-02-2003 04:16 PM
