Bravo 1 ?
Old 03-06-2006 | 03:56 PM
Default Bravo 1 ?
What is the difference,bravo 1 upper and bravo x (not a xr or xz) thanks.
eliminat this is offline
Old 03-06-2006 | 03:58 PM
GOODT's Avatar
Default Re: Bravo 1 ?
x gears are heat treated differently, has removeable steel tower and retainer is new style( thats the easy answer)
GOODT is offline
Old 03-06-2006 | 04:15 PM
Thanks. I have another ? The x upper has 1.5 ratio and I have a imco lower with 1.35 ratio can I use them together and would the ratio be 1.35.
sorry for the dumb ?'s I only know how too brake drives.
Old 03-06-2006 | 04:32 PM
GOODT's Avatar
the way im reading it if you have 15/19 tooth count in lower you ratio will be 1.5-1
GOODT is offline
Old 03-06-2006 | 04:47 PM
I dont know the tooth count will have to check,I do know they are 1.35 they where hooked up to a imco xr upper. I was told that all xr uppers are 1.5 ratio. I was also told "if you take a lower off of an xr with 1.35 ratio and put it on the x upper with 1.5 ratio it would be a final ratio at the prop shaft of 1.35."
Old 03-06-2006 | 05:03 PM
GOODT's Avatar
email me and Ill send you a copy of the gear chart didnt realize you could not see the attachment
GOODT is offline
Dave1972
6
03-30-2009 04:06 PM
1BIGJIM
Drives and Lower Units
3
06-10-2008 12:46 PM
PARADOX
0
02-27-2008 02:31 PM
articfriends
1
07-30-2006 08:10 PM
rslick
13
06-15-2005 11:54 PM
