Need some help with 502 Problem >
Old 03-12-2006 | 08:01 AM
Default Re: Need some help with 502 Problem
an injector wouldnt present a code on any scan tool
mr mercruiser is offline
Old 03-12-2006 | 08:38 AM
liquid asset's Avatar
I had the injector problem too, threw no codes and at 85 hours
liquid asset is offline
Old 03-12-2006 | 09:43 AM
briana's Avatar
I will swap computers on monday, if thats not it i will check everything else mentioned above and post findings later.
thanks alot guys
briana is offline
Old 03-12-2006 | 10:01 AM
well... first... 10 more mph is going to require about an additional 200 - 225 hp PER engine at that speed....
second... whoever suggested swapping the ecus is spot on...that gives you a quick answer right off... and the same goes for the rest of the sensor array
it sounds to me like a warrantee issue for arizona speed. also... if i read your post correctly you said you were looking for 500 hp... didn't those motors make 425 to start ? soo all this work for 75 hp / side ? sounds like a not great deal to me...
stevesxm is offline
Old 03-12-2006 | 10:39 AM
how much faster do you thnk that boat will be with an additonal 100 HP per side?
powerquest 380 is offline
Old 03-12-2006 | 11:19 AM
Dave_N's Avatar
I agree that a failed injector(s) will not set a trouble code, but did you check for trouble codes? I also agree that swapping the ECM's would be a good place to start.
While you are troubleshooting, I would disconnect the MSD boxs, recheck the timing and run without them until you find the problem. It's all about eliminating possible causes.
Dave
Dave_N is offline
Old 03-12-2006 | 03:03 PM
we had this discussion the other day and someone found a pretty good calculator on a site somewhere. i use the math.
HP = drag x V cubed ( in ft per sec)
you say you had 72 mph w/ stock 502's so about 850 hp
so back into your drag number... 850/ 1177583 = .00072
so
hp = .00072 x 1715932 ( 82 mph cubed in fps) = 1235 hp or another 385 hp total...
am sure the online calculator will give you a similar number
1050 hp should give you about 5 mph give or take
stevesxm is offline
Old 03-13-2006 | 10:43 AM
briana's Avatar
during some troubleshooting, a map sensor code came up on the ddt, i will be replacing the sensor, can this be the total problem?
briana is offline
Old 03-13-2006 | 10:45 AM
briana's Avatar
the injectors are all working correctly 46psi
briana is offline
Old 03-13-2006 | 11:46 AM
just exchange maps sensors between motors. also... don't understand your comment about "injectors working 46 psi " pressure and actual electrical injector function unrelated.
stevesxm is offline
