innercooler hose
Originally Posted by johnnyboatman
will #10 hose supply enough water to the strainer to the cooler or do i need #12 it has a 1inch id external pickup mounted on the transom
Mine has the larger going to the strainer and coming out is 12
Rob
On my Hustler with a dedicated one inch through
hull pickup. I ran 1-1/4 hose to sea strainer
then steped down after the strainer to #10
feeding the intercooler. I then used #16 on the dump side.
I was skeptical running number 10 as feed but this
produced over 10lbs water pressure (measure at intercooler) at 80 plusMPH.
When you viewed the outlet at 50mph you would not beleave the amount of water dumping.
This was a dedicated system for the intercoolers.
I Chose Bigger dumps to eliminate pressure spikes.
Gerry
Gerry
Originally Posted by ratman
strip you should use 2 hose clamps on every connection, just to be safe i always run 2
you must find out what inside diameter the inlet fittings on your intercooler are. than hose accoedingly. no need for -16 if the i.d is say 5/8. big hose will get reduced to that diameter anyways so save the money.
NJgr8ful
23
06-25-2005 08:53 PM
