Maintenance whts the best way? >
Old 03-14-2006 | 04:29 PM
flatout's Avatar
Default Maintenance whts the best way?
Just looking for tips on maintenance. Oil changes whats better draining it out the bottom into the bilge or pumping through the dip? Any tricks or tips you have on either would be great too. Drive service, I have twin alpha's whats actually done during the drive service, what do you all recommend for a service intervall? Winterizing what does it do? Last one how much power can I safely put to the alpha's? I have sbc.
flatout is offline
Old 03-14-2006 | 04:41 PM
Hydrocruiser's Avatar
Arrow Re: Maintenance whts the best way?
When I had all those questions in the same sentence I hired out..
Hydrocruiser is offline
Old 03-14-2006 | 05:09 PM
Dave M's Avatar
Veteran: Navy
Default Re: Maintenance whts the best way?
1. Installing drain hoses on your oil pans is the way to go. Stick the hose out the drain plug hole, no mess.
2. Drive service....Most importantly the alignment is checked. Change gear oil, pressure and vacuum check, lube and torque eveything to spec.
3. Winterization, most importantly keeps your engine block and othe compnents from freezing and breaking.
Dave M is offline
brwn234
Drives and Lower Units
4
01-05-2008 07:55 PM
ninetym
1
10-22-2007 08:03 PM
Summer Heat
4
06-01-2005 06:45 PM
fatdaddy
03-05-2005 08:33 AM
cloudmaster_321
7
07-06-2004 02:52 PM
