HP gain vs MPH gain? >
Old 03-15-2006 | 09:15 PM
BBB725's Avatar
Default Re: HP gain vs MPH gain?
I have an Outerlimits speed vs engine option list,if interested, for the 37' single step, only merc power so once its above 525hp they show
speedmaster drives but will give approx. speed to HP.
BBB725 is offline
Old 03-16-2006 | 06:01 AM
AKA NoMoBoatin
That would be great to see.
docmanrich37 is offline
Old 03-16-2006 | 07:17 AM
hp = cumulative drag x V cubed ( in ft /sec)
take what the known top speed of the boat is now in mph ...multiply that times 1.46 to get feet/sec
cube that and then divide THAT number into the total HP you have now... that answer is your cumulative drag figure.
now just work the formula backwards.... divide your NEW PROJECTED hp by that drag figure, and do the cube root of that for your NEW mph in f/sec.... divide that by 1.46 and get mph.... and it will be VERY very close to correct.
your neighbors 6th grader can tell you what a cube root is if youve forgotten
stevesxm is offline
Old 03-16-2006 | 07:40 AM
BBB725's Avatar
Here it is
File Type: pdf
BBB725 is offline
Old 03-16-2006 | 07:57 AM
Harper220's Avatar
Originally Posted by Tricky919
Wouldn't the speed you gain per horsepower be contingent on how efficient the hull is?
yep
Harper220 is offline
Old 03-16-2006 | 08:00 AM
Harper220's Avatar
Originally Posted by Pat McPherson
My boat went from 67mph to 75mph when I swapped a 310HP7.4MPI for a 415HP/502MagMPI...
I swapped from 7.4 310 to 496 ho in a 24 Challenger and picked up 10 mph. 60 to 70 mph
Old 03-16-2006 | 08:09 AM
AKA NoMoBoatin
Huh.Are you saying i'm old and i forgot ?Your right. thanks.
Old 03-16-2006 | 09:32 PM
traviss's Avatar
I went from my stock 270 hp 350 at 58 mph gps to my N/A 383 around 550-560 hp at 77.8 mph gps. and the boat is for sale
traviss is offline
Old 04-26-2006 | 09:51 AM
Hey Traviss, I thought you said your never selling your boat, Did you loose the need for speed for the XLT???, I bought one last year, Great Boat!!!
Dave
fyhr factor is offline
Old 04-26-2006 | 05:20 PM
articfriends's Avatar
The only problem with doing it mathmatecially is each increase in speed takes more hp per mph. My boat ran 62 mph w/415 hp,76 w/620hp (14.64 hp per mph),83 mph w/750 (18.57 hp per mph)92.8 mph w/944 hp (19.79 hp per mph),(the 750hp is a estimate) and the speeds were on gps BUT the first 2 speeds weren't labbed props which skews the data a little. If you took my current top speed minus original top speed and the 529 hp difference you would get a average of 17.17 hp per mph BUT if you factor it backwards with that my boat would have needed 655 hp to run 76 mph,Smitty
articfriends is offline
