Gear lube pump >
Gear lube pump
Gear lube pump
Old 03-23-2006 | 02:03 PM
JasonSmith's Avatar
Default Gear lube pump
Does Merc make a pump for gear lube that will allow you to fill a Bravo 1 from the bottom up?
JasonSmith is offline
Old 03-23-2006 | 02:14 PM
Mike Paula's Avatar
Default Re: Gear lube pump
I got a Quicksilver one from US boat (west marine) for mine
Mike Paula is offline
Old 03-23-2006 | 03:39 PM
JasonSmith's Avatar
does it fill from the bottom plug?
Old 03-23-2006 | 03:43 PM
All drive pumps fill from the bottom plug up.
Maritime_Eng is offline
Old 03-23-2006 | 03:47 PM
Dave M's Avatar
Veteran: Navy
Buy the pump that has the threaded fitting on it, the cheaper ones do not have it.
Dave M is offline
Old 03-23-2006 | 04:08 PM
GOODT's Avatar
Here is what I use
GOODT is offline
Old 03-23-2006 | 05:47 PM
Mike Paula's Avatar
yes. and it threads in.
Old 03-23-2006 | 06:19 PM
Mr Gadgets's Avatar
Charter Member #601
Jason,
Here is one that I had made up and have more if you're interested. Has quick disconnect and oring, dirt cap, etc.
Attached Thumbnails Gear lube pump-100_1100a.jpg   Gear lube pump-100_1103a.jpg
Mr Gadgets is offline
Old 03-23-2006 | 11:16 PM
Strip Poker 388's Avatar
Rob
Originally Posted by Mr Gadgets
Jason,
I like the quick connect.Good idear
Strip Poker 388 is offline
Old 03-24-2006 | 02:01 AM
cgarrett's Avatar
Yes they make a pump that you can get at West Marine or just about any boating store for around $7.
Cordell
cgarrett is offline
