trim pump testting question >
Old 03-29-2006 | 07:39 PM
nocigarette's Avatar
Default trim pump testting question
i need to know how to test a mercruiser trim pump to tell if they work or not,,,,what wires due i jump [email protected]
nocigarette is offline
Old 03-30-2006 | 08:50 AM
Wally's Avatar
Were doomed!
Default Re: trim pump testting question
Are you looking to do this through the soleniods or just straight pump wires?
The pump should have a green/blue/black wires comeing out of the pump motor. Black is ground.....green should make the pump trim down....and blue wire will make pump trim up.
If the solenoids are on the pump...then look where the blue and green wires are hooked to and right next to that should be another post thats hooked to the power bus bar. (the 12v that comes from the battery) you can jumper across those two connection to make the pump go up and down....
-Wally
Wally is offline
Old 03-30-2006 | 08:30 PM
GOODT's Avatar
Here You Go
GOODT is offline
jvschlegel
02-13-2006 07:31 PM
ratman
01-26-2006 07:48 PM
218diver
1
06-23-2004 11:50 AM
later
6
07-01-2003 08:31 AM
Hot Boat
1
05-30-2002 10:19 PM
