Who has the best shorties? >
Old 04-06-2006 | 05:07 PM
SCRAPMAN1's Avatar
Default Re: Who has the best shorties?
One Thing To Note Is The Imco Skeg Is Approx 2" Shorter Than The Merc Units. Depending On Set Up This May Cause Handling Problems. Also- It Is True That These Units Have Had Water Pressure Issues On Some Applications- I Had Both Issues On A Stepped Hull 42 Fountain. Hope This Helps.
SCRAPMAN1 is offline
Old 04-06-2006 | 05:11 PM
SCRAPMAN1's Avatar
Oh Yeah I Almost Forgot- I Saw No Speed Increase On Back To Back Tests Between The Imco Units And Sportmaster Mercs. On The Flip Side Some People Claim They Have Seen 2 Mph And Swear By Them.
Old 04-06-2006 | 09:01 PM
Rebel_Heart's Avatar
There would most certainly be a speed increase using either the Imco or Bravo Shop lowers vs. the standard Bravo drive, right? I would think that the combination of the shorter drives along with the bullet shaped cone would add to the speed at higher speed applications.
Rebel_Heart is offline
Old 04-07-2006 | 08:41 AM
Strip Poker 388's Avatar
Rob
Originally Posted by Ran-Dom 32
I went with the bravo shop lowers, to avoid water pressure problems & try something different, I had tried sportmaster -2 lowers prior to purchasing these. Hopefully pick up a few more MPH in the process
Did you test the diff between the reg bravo one foot VS the sportmasters you have now?Was there a diff?
Rob
Strip Poker 388 is offline
Old 04-07-2006 | 08:43 AM
Rob
Length
Imco 22"
BMax Ours 19"
Square inches of running surface:
Imco 143 square inches per side
B Max 123 square inches per side
B-Max has 40 square inches LESS running surface total.
Old 04-07-2006 | 09:11 AM
Ran-Dom 32's Avatar
Rob
Std Bravo vs Sportmaster - I gained 4 MPH but I'm convinced it was due to the fact It was a 2 inch shorty - the only real comparison I will have is the BMax vs Sportmaster
Ran-Dom 32 is offline
Old 04-07-2006 | 12:30 PM
Rob
Keep up posted on what the diff is???
Rob
Old 04-08-2006 | 05:37 AM
Hey Rad-Dom 32,
The Bravo Shop lowers look good. The water pick ups appear to be similiar to the Merc, your stock lowers are the same low pick up version that are on my '99 35 Fountain. Keep us posted on your progress, Good Luck.
RaggedEdge is offline
Old 04-08-2006 | 10:58 AM
I spoke with Dean yesterday at the Bravo Shop. Ran Dom did you send your Bravo lowers to use the existing parts or did you buy the pre-made ones? I think there is a savings of $400/set if you send in your own lowers.
GoFastSonic
Drives and Lower Units
2
07-17-2008 04:33 PM
carter38
Cigarette
5
07-06-2007 03:43 PM
briana
Fountain
47
03-26-2006 09:12 AM
SCRAPMAN1
02-23-2006 10:12 PM
SCRAPMAN1
General Racing Discussion
3
02-23-2006 10:09 PM
