-   -   head gasket recommendation for 540 (https://www.offshoreonly.com/forums/general-q/126730-head-gasket-recommendation-540-a.html)
duunoit 04-05-2006 02:37 PM
I just got my heads back and want to get the right gaskets for them. It is a N/A Gen VI 540. The gaskets that were on there before had round water passages and had trapped some garbage in the heads. I'm planning on using a sea strainer, but I'm wanting gaskets that have the bigger water passages (triangular vs. round).
*edit*
Part numbers would be a great help
PatriYacht 04-05-2006 04:16 PM
Re: head gasket recommendation for 540
Fel-Pro blue teflon head gasket is 17048.
duunoit 04-05-2006 04:35 PM
that looks like what came off of it. would it be alright to trim near the water passages?
Vinny P 04-05-2006 06:44 PM
In my opinion, Cometic gaskets are the way to go.
BillK 04-05-2006 06:45 PM
Du,
I am not certain exactly where you want to trim the gaskets, but gaskets are designed to restrict water flow in certain areas and allow it in others. By messing with the design, you could cause hot spots in the cylinder head, or the block due to improper water flow. I would leave the gasket the way it was designed and try to keep the water clean.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
customryder 04-05-2006 06:51 PM
me to
duunoit 04-05-2006 07:33 PM
if I'm not mistaken, those gaskets are made to be used on Mk4 (small round holes) and Gen 5/6 blocks (larger triangular holes)
but you're probably right. any one have a number for the cometic gaskets?
hondatv 04-05-2006 08:14 PM
BillK glad to see you here.
Is my motor ready? :D
Give me a call Donnie
Cometic in mine
nixter 04-06-2006 01:50 AM
Du,
Try performance gasket 262-677-4690....I think they carry Cometic.
