Help me build my 454, step by step >
Old 04-20-2006 | 08:03 AM
BajaRunner's Avatar
Default Re: Help me build my 454, step by step
Ok, machine shop magged and dipped the block, everythings ok.
He asked if i wanted to stud the block and align bore it?? he said it looks straight and doesnt think its necessary for what im going after but offered it. should i?
BajaRunner is offline
Old 04-20-2006 | 09:04 AM
For the power your going to make studs are not required. The line hone is either within tolerance or out of tolearance.
cstraub is offline
Old 04-20-2006 | 10:33 AM
Jerry B
There are many good comments here. Several have said to get a book or two. Tons of great info.
How much have you budgeted for this project? You can spend alot of money on good parts and not have the right combination to make the power and torque you want at the rpm you intend to use it. GM among others offer several crate engines that are dyno prven combinations and some even have a warranty of some kind.
I am looking at a Summit Performance catalog right now. A new GM ZZ502 Is 7459.95. 502 hp and could run on pump gas. All you need is carb and headers.
Any that is my 2 cents worth.
Good luck, Jerry.
Jerry B is offline
Old 04-20-2006 | 12:45 PM
Strip Poker 388's Avatar
Rob
Good luck, Jerry.
I would change the frezze plugs,cam,ck CR,ck piston wall clearance.Head gasket?,prob has a narrow .060 exhaust seat etc.
Strip Poker 388 is offline
Old 04-20-2006 | 01:16 PM
Jerry B
As I understand it this engine is going into a nova. Not a boat.
I would not recommend it for a boat without modifications as Strippoker says.
Jerry.
Jerry B is offline
Old 04-20-2006 | 05:28 PM
Rob
Jerry.
I forgot it was for a car.oops
Old 04-20-2006 | 06:39 PM
ratman's Avatar
i always have my blocks align honed so the bearing get the right crush for heat transfer, same with the rods have em resized and i always set the pins up as floating.
ratman is offline
Old 04-20-2006 | 07:08 PM
KAAMA's Avatar
I always have my blocks align honed!
KAAMA is offline
Old 04-20-2006 | 11:16 PM
bck's Avatar
bck
Charter Member#568
Unless you are trying to gain engine building skills, have you thought about crate motors ? It seems like what you want is a good application for a Chevy crate motor.
Straight bottoms and flat decks
bck is offline
Old 04-21-2006 | 12:25 PM
BajaRunner's Avatar
Well I have good news and bad news.
The bad news is the nova project is stopping.
The good news is I just picked up its replacement a 72 chevelle ss.
Its a small block car, and im going to leave it that way, so ill be back real soon to start the small block work up.
