MSD Distributor rust
Can I still use this Distributor. Is there replacement parts for the ones that are rusty.Its a MSD 8560. Don't no how the water made it in. Thanks Phil
Send it back to MSD in El Paso & they'll freshin it up for you.
If you do send it out, check out thier turn around time. Gets busy this time of year. I would also send them the MSD box to check that out as well. Ideally if you can afford to keep a spare box it would be a good idea. Seems they always go out when you need it the most.
I sent mine for a refresh three years ago. The cost was $75.00. You will receive (basically) a new distributor, cap included.
Chances are, it will not be the same one you send them.
I had a small prick punch on the base ring to help facilitate installation and get me close to base timing. The distributor I received did not have the prick punch.
It is a good deal.
It is a good deal.
Thanks Cig3. Summit has it all. Just one question anyone ever replace the reluctor in there msd billet PN-8560. I've change gears and rotors but never the reluctor. Thanks Phil
I did.. and the replacement was a bit different than the one I took off. I think there was an extra slot or something, but they just press off, not a big deal. I just cant remember what I found different.. I think I had to cut a slot in the new one.. have to revisit it..
Dick
Dick
Thanks Dick. You said it was short a slot? I have the link to summit with the reluctor showing. Does this one have the slot you were talking about. thanks again.
Phil
http://store.summitracing.com/largei...t=MSD-PRD10071
Phil
