Reversion what is the impact?
#61
Rage,
The Rhodes Lifters are my original installation. I feel I was pushing the reversion limits with the cam I am using, and thought I would try them. I installed them for reversion, and for the chance of a few extra ft./lbs down low. Keep in mind this is a small block 388, so the cam #'s don't directly correlate to your 496.
Mike,
I think your thread has been hijacked
This reversion thing is always coming up around here, and I think the more knowledge we share the better.
Mike,
#62
Originally Posted by Mike Paula
Ok Am I missing something here? You guys seem to be making a big project out of this problem. I am running a 502/502 cam with a very tight 110 lsa I took my Stainless Marine risers and lengthen the exhaust tube 12" and I have no problem I also did this with a set of Gils on a blower motor. Am I missing something here?
$$$$ headers or $$$$ blower and no reversion versus a $95 lifter conversion and no reversion.
#63
Originally Posted by jmherbert
Rage,
Mike,
Mike,
Yes the bigger the engine CID the more sensitive to reversion is what I read.
When you brought up the Rhoades lifter option I started another thread just on that to beat the bushes for more people that have tried them and their results. Feel free to jump to "Rhoades lifters eliminate Reversion from hot cams". That aught to attract some views and hopefully good feed back.
#64
#65
I do not know what Headers are on the 496 but cant the risers be modified in the same manor?
#66
What are your cam #'s? I tried a search on Crane's website with your OEM # but couldn't come up with anything.
If it were me, I would let Rhoads do the change for 95 bones, assuming your cam's # are 'big' You would not have much into it, maybe $250 total when you add gasket costs (assuming your motor is together) and two half days worth of work.
Of course, this would take boating time away
#67
The Crane web site is far from complete I have found. You have to call the Crane Tech line to get the timing card for this cam #. The cam is essentially the EFI500 so not huge but big enough to get me enough reversion to fry the o2 sensors located 1" above the stock exhaust manifold/riser junction. I've spent way more than $95 on o2 sensors already.
Actually the intake manifold and valve cover gaskets are rubber and new with new cam and heads instal this winter/spring so very reusable. The only open question is do I need different push rod length. If I send Rhoades a 496HO lifter they will tell me what if anything I need to do regarding push rod length. I cannot believe how perfect the Rhoades lifters solution seem to me. However I am still looking for some one who had reversion and got rid of it by switching to the Rhoades lifter.
Unfortunately I have run out of project time. I have been on this winter project since November (research phase) and my wife will now shoot me if I do anything other than drive the boat until this next winter. So I am looking toward the future here unless she takes a trip??????
Bill
#68
The OEM0988 cam timing @0.050 is....
- intake opens 6.0 BTDC
- intake closes 44.0 ABDC
- intake duration 230
- exhaust opens 57.0 BBDC
- exhaust closes (1.0) BTDC
- exhaust duration 236
- LSA114
- Max lift Int 0.598
- Max lift exh 0.610
- LSA114
#70
Rage,
Mike,
Mike,
Your 388, does it have knock sensors? Is it a Mercruiser or GM ECU? I am being told that the ticking noise from the Rhoades lifters closing the valves faster may be missdiagnosed as engine knock by the ECU/knock sensor programing.
Anything on this in your experience?
Bill
