Another Bravo Question(again) >
Old 04-11-2006, 11:39 PM
Thumbs up Another Bravo Question(again)
I KNOW THIS HAS BEEN ASKED AND ANSWERED MANY TIMES BUT I NEED TO GET IT ANSWERED THIS WAY SO ITS CLEAR TO ME,THANKS! IF I BOUGHT 2 BRAVO DRIVES FOR MY TWIN POWERED BOAT CAN I JUST BOLT THEM ON AND HAVE THE SAME ROTATION AS THE OLD DRIVES ?IS THE SHIFTER THE ONLY THING THAT CONTROLLS THE WAY THE DIRECTION OF THE DRIVE ROTATES OR IS THERE AN INTERNAL CHANGE ASWELL?ARE ALL BRAVO SYTLE DRIVES SET UP THE SAME INSIDE?
THANKS AGAIN
JJONES is offline
Old 04-11-2006, 11:46 PM
nordic95's Avatar
Default Re: Another Bravo Question(again)
Yes the bravo drives are made to rotate in either direction.The change would be make at the shift bracket located on the motor.Cable to the one drive would be located on the top of the arm and the other on the bottom.This way when you move your levers forward both cable move in the same direction until you get to the shift plate.Then thats were the change takes place,one goes into forward and the other into reverse.What type of drives are you replacing?
Nordic95
nordic95 is offline
Old 04-12-2006, 12:20 AM
Received 1,826 Likes on 911 Posts
Ditto to nordic95.
Griff is offline
Old 04-12-2006, 12:17 PM
Im Replacing My Regular Bravos With Xr And Imco Lowers, Thanks For The Info,i Thought That Was The Way It Was But Just Wanted To Make Sure! Thanks Again
JJONES is offline
Old 04-12-2006, 03:44 PM
Ginger or Mary Ann?
US1 Fountain's Avatar
I change the rotation by swapping the cables at the shifters, not at the motor.
US1 Fountain is offline
Old 04-12-2006, 05:15 PM
GOODT's Avatar
at the mtr wont help has to be done at the shifter as stated
GOODT is offline
Old 04-12-2006, 08:01 PM
Cool,thanks,so Does That Mean Both Drives Are The Same Internaly And Its Just A Matter Of The Cables Being Pushed Or Pulled?so It Doesnt Matter Which Side I Put The Drives On ,they Will Work Like The Old Ones Did(rotation Wise)? Thanks
JJONES is offline
Old 04-12-2006, 08:50 PM
formula31's Avatar
Yes. There are some who like to rotate their drives to even the wear and there are other (me) who prefer to run them on the same side where they are happy. Otherwise, they are the same.
formula31 is offline
Old 04-12-2006, 09:11 PM
I think it's the Volvo drive where you change the position of the shift cable at the drive. Anybody know for sure?
Edward R. Cozzi is offline
Old 04-12-2006, 09:15 PM
GOODT's Avatar
yes, if you pull the back cap off a volvo and switch the rod to the shifter lever that will reverse the rotation
GOODT is offline
Quick Reply: Another Bravo Question(again)
