should I use the old piston ring or get new ones
hello I got a 502 efi with 2 bad rod bearings no harm to the bore can I use my old ring or should I get new one I am running into trouble finding new ones the motor has less than 50hrs on it
Brent,
On a 50 hour engine, I would probably be inclined to leave the rings alone. As long as you were not haveing any type of oil problems, they should be fine. Rings are easily available if you decide to change them You can get them from GM, Speed Pro and Hastings.
I would be more concerned about the condition of the connecting rods if it hurt the rod bearings. Also, make sure the piston pins are not too tight in the pistons, that can cause rod bearing problems.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Bill Koustenis
Waldorf Md
great I have new rods and pisto an no this was not a trick question goodt
any have a part number b/c my parts guys say that they can not get any that they are metric style an I will have to go to merc. and get them
Brent I was kidding, when in dought go home ( merc )
here are your part numbers
I bought some from a local speed shop 4 years ago for a guys 502 I was rebuilding,they are in the hastings catalog,just find any shop that sells hastings products. Hastings is a common company that sells parts,sorta like melling or felpro,any performance shop should be able to look it up for you,Smitty
thats ok one more thing on the 502 is it me or do they have a oiling problem on the front end of the block is there any thing I can do extra inside that will prevent this from happen again
