-   -   Help wiring stock coil to MSD Blaster coil (https://www.offshoreonly.com/forums/general-q/128252-help-wiring-stock-coil-msd-blaster-coil.html)
MnHowardCat 04-23-2006 10:21 AM
So I'm replacing my stock coil with a MSD blaster coil the stock coil has four weirs on it with two plugs a black plug with a pink and a brown wire and a gray plug with a ren and White wire the MSD coil only has two connectors a negative and a positive post So I'm thinking the red and White go to the positive and the pink and brown go to the negative????
Dave_N 04-23-2006 11:18 AM
Re: Help wiring stock coil to MSD Blaster coil
It sounds like you have the Delco EST distributor and coil and your trying to replace the coil with a different type. If that is the case if may not work very well.
There is an exact replacement Blaster Coil for your system (MSD part #8226). You may want to get the right coil.
Dave
MnHowardCat 04-23-2006 09:13 PM
Thank's Dave I went to MSD's web site and thats the one I need they sold me the wrong one's
Don
