Article on cam failures.... >
Old 04-24-2006 | 11:11 AM
Iggy's Avatar
Default Article on cam failures....
The latest issue of HOT ROD has a good article titled "When Good Cams Go Bad".
It deals with the escalating failures of flat-tappet cams. The article sites the use of cheap no-name brand lifters, high spring pressures, improper break-in, as well as the reduced anti-friction additives in todays oils for the failures.
Pickup a copy and read it. Very informative.
Wonder if there is any correlation between these types of failures and the roller lifter failures some of you have experienced.
Iggy is offline
Old 04-24-2006 | 02:06 PM
Default Re: Article on cam failures....
I agree. It was a very well written and informative article.
Lmarth is offline
Buddy OO
Drives and Lower Units
16
08-10-2007 04:08 PM
JasonSmith
15
05-06-2007 09:29 PM
Panther
03-29-2007 02:02 PM
35/25
78
02-20-2007 07:32 PM
Goodfella
01-20-2003 07:27 PM
