Solid hub
Old 05-04-2006 | 08:46 PM
nordic95's Avatar
Default Solid hub
Here is a stupid question.I just installed Mercs. solid hub kit for an XR drive into my Bravo ones and realized there is no provision for a nut locking ring.Is it me or is it not needed for some reason.Maybe the curved washer has something to do with it?Does the curved washer go with the center of the washer curved towards the prop or away?
Thanks Nordic95
nordic95 is offline
Old 05-04-2006 | 11:12 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Default Re: Solid hub
Don't know, but my McGard prop locks use the cupped washers also instead of the locking tab. Mine are stamped to have the middle of the washer with the curve away from the prop, against the nut.
US1 Fountain is offline
Old 03-03-2011 | 05:42 PM
sleek1's Avatar
My local marine shop told me first install the spacer, then the cupped washer with the high side toward the nut (convex forward), then flat washer, and nut. This is for P/N 840383A2.
Let me know if this is incorrect, I can't find it in writing anywhere.
I know it's an old thread but it may be helpful to someone... I could have used it today.
sleek1 is offline
Old 03-03-2011 | 07:21 PM
That is correct. When you torque down the prop nut, it smashes the curved washer against the spacer, thereby putting tension on the nut itself as it tries to push back out.
Use a nylon lock nut anyway.
Philm is offline
overdrive75
Prop Talk
7
10-02-2007 10:11 AM
Shah Mat
Prop Talk
2
06-26-2007 05:05 PM
Formula Outlaw
02-17-2004 10:09 PM
jafo272
2
08-29-2002 04:41 PM
BAD-HABIT
3
08-23-2002 01:20 PM
