Hot Riser
Old 05-07-2006 | 05:53 PM
DMAX's Avatar
Question Hot Riser
502, gen6 efi not even at full run temp. starbid Gil riser almost to hot to touch while port is bearly warm any suggestions what is cause of this or is that norm. Thanks
DMAX is offline
Old 05-07-2006 | 07:43 PM
ratman's Avatar
Default Re: Hot Riser
check for a blockage, check the water pump and make sure part of the impeller isnt missing and blocking a passage. hook a garden hose to the exhaust pipe water inlet and see if it flows ok like that.
ratman is offline
Old 05-07-2006 | 07:51 PM
Payton's Avatar
Charter Member #927
Is this in the water or running on a water hose? There won't be as much water running on a hose and the left will be hotter. It will be a little warmer even in the water.
Payton is offline
Old 05-08-2006 | 04:29 PM
DMAX's Avatar
Thanks I'll try that this weekend and yes it is on a hose ,but the other motor's riser are not as warm. Thanks again.
DMAX is offline
bcfountain
2
08-21-2008 07:01 PM
East Coast B
1
06-12-2005 09:25 PM
Whiteknuckle
7
02-20-2005 03:58 PM
Danny_Ocean
1
04-20-2004 05:22 AM
