Milk in valve covers! >
Old 05-08-2006 | 11:32 AM
miamioffshore's Avatar
Default Milk in valve covers!
So I have milkshake in the valve covers on 1 of my engines. TNT says it's too much to be condensation, just pulled the intake manifold and they say it's not corroded and the leak is not coming from there. There is no milk in the crankcase oil. Where else could this leak be coming from? Engine is 1999 hp500
miamioffshore is offline
Old 05-08-2006 | 11:55 AM
CIG3's Avatar
Default Re: Milk in valve covers!
Sounds like condensation to me. ALuminum Valve covers???
CIG3 is offline
Old 05-08-2006 | 12:01 PM
Wobble's Avatar
SORE MEMBER
If there isnt milk in the pan, it must be condensation IMO. If I have to idle for an extended period before shutdown, I see the same thing.
I try and get my oil-temp above 220 before heading for the trailer, seems to keep this issue under control.
I recently noticed that I would get some condensation inside the oil fill cap when I ran the boat on the hose for about 30 minutes, I will avoid that as much as possible in the future.
Wobble is offline
Old 05-08-2006 | 03:08 PM
I am getting the same. I just redid my top end , I am still convinced its my intake gasket . I just installed another intake gasket and its still leaking. I am going to tryto swap out those little allen head bolts one by one and put a big flat washer underneith a hex bolt and retorque. Do you think that will seal it ?
drewwilliams is offline
Old 05-08-2006 | 08:05 PM
Got an oil temp. gage? If the oil temp. is less than 212*F., then water (one of the products of combustion that will get into the pan and oil system) will not be vaporized and extracted completely through normal ventilation and will show up as "milk shake" on your breathers and valve cover fill caps. But, if you have "milk shake" elsewhere you need to check the gaskets or for that little crack that got missed at rebuild time. After confirming that your oil is reaching proper temp. then go to a leak-down test. --- Jer
jpclear is offline
Old 05-08-2006 | 08:59 PM
MOP
If the oil in the pan is fine it is condensation, on raw cooled motors it is more of a problem then on closed cooling setups. Higher engine temp helps a lot. Some engines have PCV valves if you have them change them that will help some. Getting air to flow through will help, I put a breather on my port valve cover and two hoses off the starboard up to the air cleaner to draw more air but I also have closed cooling. Another thing is if you run in "fresh water" go to a 180 thermostat that will help to cure it plus you may find a tiny bit more power.
Phil
MOP is offline
Old 05-08-2006 | 09:34 PM
Yes, and I cant get a reading on it, never comes on, that engine has always run at 3 psi water pressure wide open (crossover no t-stat) the other runs 5 psi water pressure and has no condensation. I'm going to put the re-circ pump back on & t-stat back in. But in the mean time tnt says the milk has rusted my valve springs etc, and I need a rebuild? Any suggestions?
Old 05-09-2006 | 07:38 AM
CIG3's Avatar
Post pics of the valve spring. How many hours on the motors? May only need valve springs. If your not over 250 hours on an Hp500 your should be fine. If you replace the valve springs use Isky Toolroom.
Your motor should have a oil thermostat, if not consider one.
my $.02
CIG3 is offline
Old 05-09-2006 | 10:17 AM
Dont you think if you stick 2 fingers in the oil fill hole and they come out green and foamy thats too much condensation or something more?
boatman747 is offline
Old 05-09-2006 | 10:46 AM
Wobble's Avatar
SORE MEMBER
probably just condensation, however, if you let the motor sit for an extended time with that in there it will attack the valve springs and possibly valves.
Wobble is offline
