Crane HI-6M Ignition >
Old 05-11-2006 | 10:27 AM
pachangalpina's Avatar
Default Re: Crane HI-6M Ignition
Motorstate is currently out of stock of these. As well as most places.
MSD and Crane both recommend using anti-vibration mounts and not to mount to engine. I still mount mine to the engine but the mount bracket has rubber bushings and the boxes are mounted to the bracket the same way.
pachangalpina is offline
Old 05-11-2006 | 02:51 PM
axapowell's Avatar
Where To
I mounted mine on the transom between the exhaust. It's only about 10" from the coil and distributor. I used hanger bolts (screw on one end and regular threads on the other and put a rubber bushing in between the box and the boat.
Dave
axapowell is offline
Old 05-11-2006 | 02:53 PM
Blue by You's Avatar
FIERCE ALLEGIANCE
Dave
Got a picture?
Blue by You is offline
Old 05-11-2006 | 03:02 PM
What are you doing for motors jim??
NOMOGOFAST is offline
Old 05-11-2006 | 03:27 PM
FIERCE ALLEGIANCE
Hey Don!
Right now just rebuilding the HP500's. New Heads/Cams and intakes. Should be around 550 maybe 600HP if I'm lucky.
Winter project will be to either supercharge these or just find new power. I'd like to just get the boat in the water this year.
Old 05-11-2006 | 03:38 PM
When you mount it spend some time and relocate the stock components nearby. You can then plug n play between them if the Crane box fails. Only need to carry the spare rotor then. I have run my used Crane box for years and it still works fine.
BadDog is offline
Old 05-11-2006 | 03:43 PM
FIERCE ALLEGIANCE
Thumbs up Re: Crane HI-6M Ignition
Good idea.
Old 05-11-2006 | 04:45 PM
FIERCE ALLEGIANCE
Whoo Hoo... it pays to be persistent; Sold!
http://cgi.ebay.com/ebaymotors/CRANE...ayphotohosting
fastlane40
08-09-2008 01:33 PM
Dino
5
06-19-2008 06:12 AM
DesertRage
9
02-02-2008 06:48 PM
DesertRage
Wanted
2
01-30-2008 09:52 AM
fastscarab22
1
11-05-2007 04:47 PM
