Is It True
I Have A 91 454/b1 And Was Wanting To Use Synthetic. I Was Told By A Mechanic That If I Start Using It Now It Will Leak From Every Seal.is This Something That I Should Worry About.
Re: Is It True
Sounds like urban myth to me. Where's his research and data coming from?
Re: Is It True
HE CLAIMS THAT IN ALL THE OLDER MOTORS THAT HE HAS SEEN SWITCH TO SYNTHETIC HAVE DONE THIS. |
Re: Is It True
I doubt EVERY seal will leak. I have "heard" that synthetic may leak through seals.
If your motor is stock, don't bother switching. |
Re: Is It True
Your Mechanic is dead wrong. Ask him to explain why. Guarantee he has no real explanation.
Re: Is It True
I don't fully understand this however I can tell you that I run synthetic in my 1989 454 bravos without leakage.
I use synthetic gear oil in my 72 SS Chevelle M22 transmission and it leaks through the side cover. It never leaked with conventional gear oil. I don't know if this is related to the particle sizes or surface tension, but I know from experience it leaks in the tranny. bbcngineer |
Re: Is It True
Re: Is It True
I had about 175,000 miles on my 94 GMC 1/2 ton pickup with a 350 in it when I tried synthetic. Yes, it seemed like it was leaking badly out of every seal on the engine. I know that there was some seepage before the change but now it was leaving puddles instead of a few drops here and there. I changed back for that very reason. I did, however, change the grease in the differential to sythetic with no leakage at all. No urban myth, just my own experience............and that's all I have to say about that.
Roger |
Re: Is It True
Synthetic oil typically isn't as "thick" but has superior lubricating properties hence it will be given higher viscosity ratings. That's why sometimes the seals leak. In a sense, if you had a leak before it may get worse because the oil is a little thinner. You can make the same thing happen by switching from a 40wt oil to a 5W 30.
He is probably blowing it out of proportion but there is a "little" truth. |
Re: Is It True
Thanks I Will Give It A Shot,hope I Don't Have A Bilge To Clean Soon.
| All times are GMT -5. The time now is 10:02 AM. |
