Too high of 7.4 RPM?? >
Old 05-22-2006 | 12:25 AM
Default Too high of 7.4 RPM??
Hi guys, recently bought a new boat...well it ten years old. Its a powerquest 290 with 23p 3 blade mirages. (i believe this is factory fit) It also has 330 hp 7.4Ls. It turns just shy of 5000 RPM at WOT. Doesn't this seem a wee bit high for a factory set up? It just does not seem like a safe level..input? thanks
Chicago290 is offline
Old 05-22-2006 | 12:48 AM
dean51267's Avatar
Default Re: Too high of 7.4 RPM??
I turned my 93 model 330hp 454's 5,000 all day with no problem, I think factory specs are that power loss starts at like 4800 rpm though....
dean51267 is offline
Old 05-22-2006 | 06:41 AM
GOODT's Avatar
the above is correct, the revlimiter will kick in at 5200 if im correct you should be between 4400-4800 rpms go up one pitch size
for every inch in pitch you go up you will go down in rpms aprox 200 rpm
GOODT is offline
Old 05-22-2006 | 07:06 AM
Whiteknuckle's Avatar
Thats perfect, leave it alone and don't worry about it. Who ever had the boat before you has it propped perfect.
Whiteknuckle is offline
Old 05-22-2006 | 12:33 PM
Thanks for the input guys. Think i'll just leave her be.
Old 05-22-2006 | 01:39 PM
BajaRunner's Avatar
thats high isnt it? I thought you didnt want to rev over 4600 on the 7.4's?
BajaRunner is offline
Old 05-22-2006 | 03:16 PM
Pat McPherson's Avatar
I found that my 1989 330HP/7.4Carb made peek power at about 4900rpm. At least propping my 24' Pantera there was the fastest.
I had a 1999 310HP/7.4MPI in my 24' Super and that pushed the boat fastest propped at 4500rpm.
I believe that the Gen VI roller cam 7.4L engines peak sooner than the flat tappet cam Gen IV & Gen V engines.
The engine should live at 5K, but I'm surprised that it does not have a rev limit before.
Patrick
Pat McPherson is offline
jijo
4
06-11-2008 06:57 AM
nadledvinka
8
06-29-2005 05:31 PM
Sates
8
04-16-2005 02:45 PM
MAX VELOCITY
6
07-29-2003 10:13 PM
kathycool
10
07-01-2003 09:13 PM
