-   -   rebuilt trans dosn't work? (https://www.offshoreonly.com/forums/general-q/130882-rebuilt-trans-dosnt-work.html)
Scarab3DMC 05-23-2006 07:34 PM
I had a local Merc Mechanic rebuild both of my Borg Warner 72-c trannys....put the motors and every thing back together..fired them up today...Starboard works great ...port does NOTHING...FORWARD OR REVERSE...????any suggestions???..I hate to think of pulling the motor again.... :mad: :mad: :mad:
Pwrbt33 05-24-2006 06:10 AM
Re: rebuilt trans dosn't work?
If you have nothing and the fluid is not being pumped, he may have set the pump up for reverse rotation by accident. Start the motor up and crack a line loose to see if you have any fluid movement in the hoses. You cant really put the shuttle valve together wrong. Usually when the dont work, its the pump housing is clocked wrong.
Sorry for the bad news if thats it. You will have to pull it out.
John S.
Mbam 05-24-2006 06:43 AM
What he said.
Scarab3DMC 05-24-2006 06:43 AM
I'll try that,,,thanks...Dave
Scarab3DMC 05-25-2006 07:23 AM
THANKS GUYS...EXACTLY CORRECT !!!!, PULLED THE MOTOR FRONT COVER WAS 180 degrees off... now I know what you ment by "CLOCKED'' wrong...thanks...Dave :evilb: :drink: :cool:
gotime34 05-25-2006 08:02 AM
This same exact thing happened to me last season, but with both sides. Had to pull them both...I was not happy.
Pwrbt33 05-25-2006 11:12 AM
:D Glad to hear that was it! Hopefully it wasnt to much trouble.
John S.
Scarab3DMC 05-26-2006 08:08 AM
I installed trans pressure gauges & senders...but I can't get them to work..I ran 14 gauge wires to the gauges...I have a good ground..I turn the ignition on and the needles move up 3/16''..I installed the senders in the 1/8 pipe plug next to where the old temp sender was 3/8 pipe...I noticed another 1/8 plug on the front cover..I was told thats "reverse" pressure... ??gauges and senders are Livorsi...
J-Bonz 05-26-2006 08:17 AM
Dave,
Sorry, i dont have any advice but, keep us posted. I am looking to do the same here.
Jr.
Mbam 05-26-2006 08:27 AM
The 3/8 plug is the line pressure.
