running hot
Old 05-23-2006 | 08:34 PM
johnnyboatman's Avatar
Default running hot
ive got twin 557s w/innercollers, 871s w/twin dominators when i run it one motor goes to 170-180 on the gauge the other shows about 140- flows plenty of water out the exhaust, run crossovers, last year it was the same side heating up maybe the gauge is bad?vacuum leak, timing?
johnnyboatman is offline
Old 05-23-2006 | 08:47 PM
eyezlee's Avatar
Default Re: running hot
running thermostats? maybe one is bad.
eyezlee is offline
Old 05-23-2006 | 08:52 PM
no thermostats
Old 05-24-2006 | 09:59 AM
swap the senders...?
TxHawk is offline
Old 05-25-2006 | 06:40 AM
LAKESIDE RESTORATIONS's Avatar
Lakeside Restorations.com
How are your impellers??
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
LAKESIDE RESTORATIONS is offline
Old 05-25-2006 | 07:47 PM
monstaaa's Avatar
all of the above ,also if you have bravos, check for bravo fever, the inlet hose that runs from the gimbal helmut to the transom assy has that little nylon insert. sometimes the corrosion builds between it and the housing itself closing the inlet hose and she may run hot. also check for debri in the oil cooler on the inlet side. and chech all connections , especially on the suction side of the water system
good luck
monstaaa is offline
Old 06-11-2006 | 08:05 PM
fixed it, the lower unit had a nose cone welded on that was restricting flow
Big Block Billy
21
09-23-2007 08:24 AM
robclark
6
07-31-2006 09:25 PM
beachbob
1
02-16-2006 06:29 PM
dallas01
0
06-22-2004 01:26 PM
yesrej
1
08-13-2003 09:37 PM
