Mesa's Baddest Turbo Power >
Old 06-08-2006 | 09:22 PM
  #31
WeaponX's Avatar
Default Re: Mesa's Baddest Turbo Power
Originally Posted by Bigyellowcat
On that note for everyone on here to be a witness, I have $10,000 I will give you to bring that motor up here and make more power then mine on the same dyno.
I'll bring my motor down for $10,000.
WeaponX is offline
Old 06-09-2006 | 12:50 AM
  #32
Originally Posted by MESABALANCING
Tom the turbos we're using with the engine management system makes these engines as user friendly as your everyday marine engines . Garrett has really helped us with the development of the turbos and innovate has also helped us tremendously with the boost control anyone wanting to go turbo should really try their products.
If your having Garrett develop those turbo's , maybe you could get them to make them with a water jacket so you can put them in a boat.
NOBODY is offline
Old 06-09-2006 | 07:54 AM
  #33
As an armchair engine builder, I always enjoy Laz's posts.
A lot of engine builders don't post here because it always ends in a debate. I think Laz is a gearhead like alot of us and enjoys discussing his craft. Regardless of what is claimed, at least we get to see some engine development(and don't have to pay for it ourselves).
So continue the posts Laz...
vtec is offline
Old 06-09-2006 | 08:01 AM
  #34
Garrett recommended these turbos the way they are for what we're using them for they claimed they didn't have an exhaust turbo housing the size we needed at the time we purchased them and guarantied them to work .
MESABALANCING is offline
Old 06-09-2006 | 08:35 AM
  #35
They are not these engines?
if they are then you are a liar about the hp they made if not then explain what they are and we will see if they can make that kind of HP
Tyson there is a discrepancy here and the engines are not the same ci anymore 6 months after we started the customer decided to go bigger after one crank was cracked and 7 rods were bent I hadn't paid any attention to the first post the engines are 3.850 stroke and 4.440 bore now and you're right I hadn't paid attention to the first post. I can tell you we dynoed on of the engines when they came in and it made 1200hp but not on pump gas . If we get to the point I did screw up in not clarifying the size of the engines now my bad.
Old 06-09-2006 | 05:00 PM
  #36
offshoredrillin's Avatar
just my look on it as I dont have a dog in this fight...
Laz is saying they did all the research, even thought the nitro rings arent his. even though the engine has been gone through with numerous changes and is using different turbos.
Tyson is saying the exhaust, intake and the bracketry is the same as the barn engines and that Laz shouldnt be taking credit for "engineering" this when all he is doing is continuing where someone left off.
Sooooo the question is, is Laz correct in saying that the new part of making these engines run correctly is his design, or Tyson saying that all he did was take someone elses stuff and continue with it.
offshoredrillin is offline
Old 06-10-2006 | 07:54 AM
  #37
KAAMA's Avatar
I agree, I have always gleaned from Laz's posting. He is a reputable wealth of knowledge, and is an asset to the performance boating community and this forum.
KAAMA is online now
Old 06-10-2006 | 05:26 PM
  #38
These were originally Mike Moran Quad turbo motors right?they were outlawed before he even showed up with one,bad azz!
captgator is offline
Old 06-10-2006 | 06:55 PM
  #39
SB
I agree.
I would also like to see the progression / taming / etc,etc of a motor project like this. Not an everyday event.
Let's try to start this whole thread over. Too many typos, not giving history on these motors, etc,etc,etc
Ok, so we have a 4.440 bore and 3.850 stroke.
476.9 cid......................
SB is offline
Old 06-27-2006 | 09:26 PM
  #40
eyezlee's Avatar
What's the latest on this project?
eyezlee is offline
