backfire above and near 3000 rpm's? >
Old 06-22-2007 | 09:40 PM
  #51
flatout's Avatar
copy that good idea.
flatout is offline
Old 06-26-2007 | 10:52 PM
  #52
I just had the same problem with my 350 mag. I had 2 plug wires reversed. I was positive I had it right, untill I spent a couple hundred on parts I didn't need and did some checking.
magstang1 is offline
Old 06-26-2007 | 11:48 PM
  #53
cuda's Avatar
Originally Posted by rumblfish1966
quit screwin around and change the COIL thats prolly it
The next bad coil I find will be the first bad coil I've found, even though many times I convince myself it HAD to be a bad coil. I have several extra coils laying around to prove it. Usually when someone tells me they fixed their problem by changing a coil, it's because they most likely fixed the bad connection to the coil. There's not a whole lot that can go wrong inside a coil. It's just a big winding of wire. Anything bad on a coil you most likely will be able to see from the outside, like a crack.
cuda is offline
Old 06-27-2007 | 04:51 AM
  #54
flatout's Avatar
mustang 1 If it turns out that easy i will be flamed after everything I tried and the money I spent.
flatout is offline
Old 07-02-2007 | 10:15 PM
  #55
check it out man. I was SURE until I bit the bullet and looked again. Sure enough. Good luck. And yes I did catch some major heat.
Old 07-16-2007 | 01:41 PM
  #56
flatout's Avatar
OK my friends refer to me as Ricky the re re. for a whole year I thought it was more serious. its official The #5 and #7 wires were swapped. went out yesterday now without the new stuff I bought and can tell I am not getting full throttle only reved to 4000 rpm but felt like it had more. 54 on gps with 19inch mirage plus.
flatout is offline
speeddemon651
46
08-28-2016 01:33 PM
madorno1
09-22-2007 11:05 PM
Rocko C
7
08-27-2007 12:07 PM
MitchStellin
17
05-17-2004 09:01 PM
Keith
31
05-28-2003 07:56 PM
