trim tab problem >
trim tab problem
trim tab problem
Old 06-13-2006 | 08:34 PM
tuffenuff355's Avatar
Default trim tab problem
trim tab goes down but will not go up , if i press in up position the solinoid doesnt even click. I jumped the solinoid that controls the up and it raised the tab. Could my problem be the switch? I havnt tried swapping the switches yet if i have to i will I figured there are some pretty knowledgable people on here that could give me a quick answer THANK YOU in advance
tuffenuff355 is offline
Old 06-13-2006 | 09:14 PM
BajaExpress's Avatar
Default Re: trim tab problem
I would suggest taking a 12 volt test light and ck 12v power to both trim switches, then work the switches and ck out put of trim switches. If all is okay at switches, go to motor and ck same wires from switches to solenoid's and ck for 12v. Be sure to recheck all grounds!!
BajaExpress is offline
007joe
Do It Yourself, Boating on a Budget
13
05-24-2008 10:27 PM
pol98xc6
1
06-05-2007 01:05 PM
Z06vette
1
06-03-2006 10:18 PM
26sonic
Sonic
8
05-12-2006 09:23 PM
32 thunder
04-20-2003 09:54 PM
