Question on Oil Temps & Coolers >
Old 06-15-2006 | 08:27 AM
Dock Holiday's Avatar
Charter Member #34
Default Question on Oil Temps & Coolers
Do I need larger more efficient oil coolers?
Merc 500 EFI's, with Merlin Heads, 741 Crane Cam, 9.25:1 Compression, dyno'd at 590 HP.
Engines in stock mode ran 190 degrees on oil temp even for extended WOT runs. After the above modifications I am usually at 215 to 220 degrees and it will rise a little to 230 / 240 degrees on WOT runs.
I have always ran Mobile 15W50 oil with good results.
Would like to cool the engine oil temps back down.
Any suggestions would be appreciated.
Dock Holiday is offline
Old 06-15-2006 | 08:35 AM
Default Re: Question on Oil Temps & Coolers
bigger cooler... but i think your ok at that temp?
customryder is offline
Old 06-15-2006 | 09:41 AM
Reed Jensen's Avatar
Leave it as it is. Oil has the most lubricity at 200 degrees. The fact that you run at 215 to 230 is good. Since your oil is above the boiling point of water you won't be getting condensation in your oil. Oil starts to break down when it climbs to 300 and beyond.
Reed Jensen is offline
Old 06-15-2006 | 11:34 AM
TC's Avatar
TC
Dock, I believe you are fine with your posted temps. Someone posted a merc bulletin a while back that stated 300 degrees at the sump was the limit. That's considerably hotter than I would run mine but they say its acceptable.
TC is offline
Old 06-15-2006 | 06:23 PM
Charter Member #34
Thanks for all the replies.
Guess I will leave well enough alone.
Old 06-15-2006 | 07:57 PM
Pwrbt33's Avatar
I have to agree, these temps are great! Theres a lot of people that would kill to have temps like that.
John S.
Pwrbt33 is offline
Old 06-16-2006 | 01:55 PM
Charter Member #34
Okay, on another forum a guy asked what my water pressure was.
At WOT I am close to 25 PSI on both engines.
This was his response:
Ok I think you need bigger coolers. Thats allot of pressure.
How will pressure effect this in your opinion?
Dock
Old 06-16-2006 | 03:46 PM
BajaRunner's Avatar
My oil temps went up, when i bumped my rpms up with the upgrades similiar to yours dock, especially at WOT. I get in the 250 range when running 5500-5600. I tried some props that were too big, and wot was 5000, oil temps never rose above stock temps, so i guess the added rpms are a big contributer to the heat..
BajaRunner is offline
Mr Gadgets
58
12-21-2007 11:54 AM
alliedtf1
2
06-25-2007 09:42 PM
delsol
5
08-31-2003 07:09 PM
ActiveFun
08-14-2003 02:58 PM
ActiveFun
06-18-2002 11:43 AM
