-   -   Warning Light Stays On (https://www.offshoreonly.com/forums/general-q/133226-warning-light-stays.html)
roarkace 06-20-2006 08:17 AM
After start up warning light stays on.All guages read normal.Disconnected all the wires from the sending units ,but the light still stays on .Any help?
Wobble 06-20-2006 09:26 AM
Re: Warning Light Stays On
On older boats the tan/blue alarm wire is connected to 1/low oil pressure switch 2/high water temp switch 3/drive oil reservoir.
the alarm will sound if any one of these switches closes and makes ground.
roarkace 06-20-2006 10:34 AM
Thanks ,sounds to me like if the switch goes to ground the alarm goes on.So if i have all three wires are disconnected and the alarm still goes on ,one of these wires must be grounding somewhere! I'll do somemore looking.
Wobble 06-20-2006 10:48 AM
Make sure you are disconnecting the tan wire with the thin blue stripe. Also look for corrosion in the big main harness plug to the engine.
