All Tickie... no turnie >
Old 06-21-2006 | 11:36 AM
fund razor's Avatar
Default Re: All Tickie... no turnie
Lib21... you out there?
You know cobras. Any thoughts?
fund razor is offline
Old 06-21-2006 | 12:01 PM
Yeah, I'm here, and I'm reading.
I just haven't come up with an opinion yet.
Paul
Liberator21 is offline
Old 06-21-2006 | 02:29 PM
Is it only making noise in reverse?
Old 06-21-2006 | 02:40 PM
fund razor's Avatar
noise is full time.
steering problem (loss of response from steering wheel input) seems to be worse in reverse.
Old 06-21-2006 | 03:33 PM
articfriends's Avatar
I don't know what omc uses for a gimbal but it sounds like it broke or fell apart part way,Smitty
articfriends is offline
Old 06-21-2006 | 03:52 PM
You might have puked a gimbal bearing, or a "U" joint (as has been said).
Don't drive it like that. You'll do damage to the transom assembly. Pull the drive off, and check the bearing, and joints. Also check the shaft going into the drive for play. Let us know what you find. Changing a gimbal bearing is easy (with the right tool).
Paul
Old 06-21-2006 | 04:00 PM
fund razor's Avatar
I only ran it about 20 minutes back home last night.
I kept the wheel as straight as possible. No S turns. No top speed.
There is a hoist at the end of my dock, so I will use the other side to get it to the hoist and pull the boat before I run that side.
I will pull the boat tomorrow or Friday.
I was just kind of trying to get an idea of what I might be looking at so I could noodle it around in my brain.
Old 06-23-2006 | 07:44 AM
fund razor's Avatar
Pulling it today. We shall see what it looks like.
Old 06-24-2006 | 10:11 AM
Wobble's Avatar
SORE MEMBER
Well?.........
Wobble is offline
Old 06-24-2006 | 09:53 PM
Question Re: All Tickie... no turnie
Well????
