-   -   What can cuase no oil pressure? (https://www.offshoreonly.com/forums/general-q/133667-what-can-cuase-no-oil-pressure.html)
OhioRiverCigarett 06-25-2006 09:59 PM
I have just installed new engines. Fired right up. You could hear the lifter build up, but had no oil pressure on gauge. I pulled the sending unit and switch to a mechanical guage. Still no presure. I think I have oil presure from how the engine sounds, but I don't like to wish.
How should the remote oil filter and oil cooler be plumbed? :cool:
BigSilverCat 06-26-2006 03:09 AM
Re: What can cuase no oil pressure?
have JCperv build your motors.
sorry I could not resist.
Wobble 06-26-2006 11:33 AM
no pressure on both engines? is there oil in the bilge? I have seen oil gallery plugs left out, oil pickup not installed etc.
pull distributor and using an oil pump primer tool (available at some parts houses and all speed shops) and an electric drill see if you can make oil pressure.
BTW, i would recommend using this tool prior to starting any new engine,
GOODT 06-26-2006 11:50 AM
i HAVE TO AGREE WITH WOBBLE, also check bypass valve
1BIGJIM 06-26-2006 12:51 PM
I left a gallery plug out and had oil pressure until all the oil pumped in to the bilge :eek:
I even had it on a primer pump and could not hear the oil squirting out the side of the block. I guess years of listioning to open exhaust and loud engines.
Did you weld the pickup on the oil pump, if not my guess would be pickup fell off or related.
gsmith9898 06-26-2006 02:13 PM
oil pick up falling off.
PatriYacht 06-26-2006 02:20 PM
Oil come out of the engine from the port on the side of the oil filter pad adapter. It goes back in the center of the pad adapter.
mopower 06-26-2006 04:34 PM
Use a priming tool as discribed above and a mechanical guage to verify the problem. Could the two sending units (oil pres/alarm ) be switched by mistake?
