HP500 stalls when getting on a plain >
Old 06-28-2006 | 11:49 PM
Default Re: HP500 stalls when getting on a plain
Drained the fuel tank today and had the same problem. I didn't see any water so I guess I'll be replacing the fuel pump tomorrow. It's a very strange problem. It idles fine, I can rev the motor when I'm in the slip but as soon as I try to get it on a plane, it stumbles hard like it ran out of gas and comes back to life once the RPM's are down.
Is there anything else I should check before replacing the fuel pump?
Thanks for everyones imput so far.
269Scarab is offline
Old 06-29-2006 | 02:26 AM
vandeano's Avatar
Is there any way that you could disconnect the fuel line that goes into the tank or just use another gas line and feed it into a 5 gallon gas can and take it for a spin. That way you know your feeding it fresh gas from a separate container. Also does your fuel pump have the clear hose that runs up into the carb. I guess it clear so that you will know if it is bad because you'll see fuel going thru it.
vandeano is offline
Old 06-29-2006 | 03:08 AM
mats's Avatar
As have been said, hook up a separate gas can + a fuel pressure guage and take it for a run. That will give you a clear answer if it is the fuel quality or something in the fuel delivery system.
mats is offline
BillR
5
05-12-2006 09:36 PM
BillR
6
05-08-2006 11:15 AM
BillR
3
04-18-2006 09:32 AM
Love Machine
22
05-24-2004 09:18 AM
bowtie89
6
07-03-2003 03:25 PM
