The Truth About Your Dyno Test
#31
Originally Posted by Michael1
If this is the case, you can throw out just about every dyno run as being too high. SAE J1349 states a standard barometric pressure should be 29.235, and standard temperature of 77 degrees. That's a mile from 29.92 pressure and 60 degrees. Add this to the fact that most of these tests are not run as installed in the boat (accessories missing, different intakes, different exhausts, different fuel, non-stablized tests run on the fly, etc), and the conclusion is, THESE AFTERMARKET DYNO TESTS ARE A JOKE.
Michael
Michael
If you can find a dyno shop that will do it fully or almost fully accessorized with exhaust and they set up the dyno correctly without fudgung it is money well worth spending.
If they don't, then fug it. And why post bogus info on top of it ? Just to take away from the builders/dyno guys that do ? That's wrong and plain old deceiptful. Not too mention you are actually stealing money from the customer.
Schit - instead of paying someone $500-$700 for incorrect info, shoot me an e-mail and $100, and I'll do the same for you, without your motor. Not much difference since unusable data is plain old unusable data.
Anyway - hitting the dyno is well worth the money......just make sure you are getting what you are paying for.
#32
Originally Posted by offshore ginger
i have to say , that after working at baker eng ,out of nunica mich . i have seen some shady things . i also have to say that , if we had sterlings in a boat jack would fudge the numbers on a dnyo and tell the customer that there h .p. was very off , and try to sell them a up grade . i can not tell you how many times . i was told to keep my mouth shut or be fired , because baker motors were exploding and sterlings were not . i guess what it amounts to is a hill of beans, one lie for another , DYNO FUDGE . just my 2 cents G . G .
#33
DUDE WHATS UP ? I AM FROM SAGINAW . I HAVE TO TELL YOU THAT JACK IS BETTER AT RACE APPLICATIONS FOR RACE CARS THEN MARINE . I GUESS WHAT IT AMMOUNTS TO IS , HOW MANY TIMES DID YOU SEE CAT , CAN , DO , OFFSHORE RACE TEAM , CROSS THE FINISH LINE WITH BAKER MOTORS , MAYBE ONCE . I HAVE TO SAY THAT WHEN THAY RAN STERLINGS , THAY WERE HOT !! I ALSO HAVE TO SAY THAT IN ALL THE YEARS I WORKED THERE . I HAVE NEVER SEEN MORE PEOPLE BRING THERE BOATS BACK , BECAUSE OF THE WORK THAT WAS DONE . JUST MY 2 CENTS G . G .
#34
Originally Posted by rmbuilder
Rob,
First let me point out that no matter what correction factor (SAE J607 or J1349) you are using in your test session, the SAE clearly states that if correction factors in excess of 7% occur during the testing, the results are invalid and the input criteria must be brought to within accepted parameters. Simply put, valid dynamometer testing is not conducted under any conditions cited above. Testing is never valid with 133º F ambient temps at the inlet, or in the eye of category 3 hurricanes. The only way this level of C/F can be arrived at is to source 133º ambient air, or externally heat the temp sensor and manually input grossly depressed baro/altitude readings. All creditable dyno facilities and R&D programs use control limits on these inputs to keep them within acceptable levels. When you alter the atmospheric inputs you cannot control the accuracy and repeatability of your pulls and your time, money, and “data” are wasted. I have been to facilities that are repeatable to within <1 HP
Bare in mind, a 15% C/F on an engine making 650 OBSERVED HP is 747.5 CORRECTED HP. That calcs to 97.5 additional HP due to “atmospheric conditions”. That is not a legitimate test.
This is a good example of the level of variance in correction factor due to prevailing conditions:
The SAE correction factor can be approximated using this equation:
CF = 1.18 * (29.235 / Bdo) * ((square root (To + 460) / 537) - 0.153)
where CF = the correction factor, Bdo = the dry ambient barometric pressure in inches of mercury (in/Hg), and To = the intake air temperature in degrees Fahrenheit.
Test 1: The Baseline Test
Let's test this equation with a hypothetical engine that dynos at 100HP. We test this engine on a 77 degree day, at sea level. So, we set Bdo = to 29.235 in/Hg and To = to 77F. When we solve the equation for CF, the correction factor equals 1. That means according to SAE, our dyno reading does not require a correction factor for temperature or barometric pressure. It is a true 100HP engine.
Test 2: Temperature = 87 degrees F, Pressure = 29.235 in/Hg What happens when the temperature climbs by 10 degrees, but pressure stays constant? Plugging in 87 for To and 29.235 for Bdo, we can calculate the value of CF. CF = 1.0104. Working our correction factor equation backwards, we take:
100hp / 1.0104 = 98.97hp.
So, according to the SAE correction factor, a 10 degree increase in temp should result in a loss of 1.03% of rated horsepower, or 1hp on our engine.
Test 3: Temperature = 77 degrees F, Pressure = 28.235 in/Hg
What happens when the pressure drops by 1.0 in/Hg, but temperature stays constant? Plugging in 77 for To and 28.235 for Bdo, we calculate CF and find it equals 1.042.
100hp / 1.042 = 95.96hp.
So, according to the SAE correction factor, a 1 in/Hg drop in air pressure should result in a loss of 4.04% of rated horsepower, or 4hp on our engine.
It required significant input to raise the C/F 4%. Also if temp goes below 77 deg F and baro rises above 29.235” the result is a negative correction factor. (Example:55 deg/ 29.92”) Corrected HP will actually be less than observed HP. Easy to do, but hard to find.
Rick,
You can quantify and qualify the variables in these equations by checking the historical data archived on sites like weather underground. All conditions are listed for all regions in the USA by date, hour, and location. For example, if you need the atmospheric conditions for Atlanta, on 9/19/2005 at 3:09 PM, the site will provide you with data from multiple locations in the Atlanta area for that period. Plug that in, with your elevation, and your C/F will be accurate +/- 2 tenths of a %.
Attached is a program used for testing to evaluate and graph BSFC # vs. TQ, BMEP, etc. It also gives a peak into correction factors.
Bob
Rick,
Bob
#37
So on a 750 hp motor If the temp dropped 30 degrees from the base line test of 77 degree Calibration the % would be 3.09% =23.17 HP ????
Bob is this SAE what most Dyno shops use?????????
SAE J1349
SAE J1349 standard of 77?F (25?C) / 0% humidity / barometric pressure of 29.234 in-Hg (99 KPa).
So if I run my boat on a 30 degree cooler day it will pick up 23.17 HP ?It Shouldn't right? But why does the boat go faster with the cooler air?
Rob
#38
What should the correction factor be on these #'s
Bro 29.85
93 % Hum,raining
Air inlet temp of 88
Sea level
Bro 29.85
93 % Hum,raining
Sea level
#39
I posted this on the thread with the pictures of my motor, but will put it here also. I NEVER SAID THE UNCORRECTED POWER WAS 659 HP. Articfriends posted that, not me. The bsfc and fuel numbers are not correct. This was the first time that I used this dyno, since I just moved to Tenn. I have built this very same motor over 25 times, and they have all been the same on 5 different dynos.
I am not some fly-by-night, jack leg engine builder who just started building last week. I have been doing this for a long time. If you have a problem or a question with what I am doing, them address them to me. Thanks, Eddie
#40
