HELP!!! Pressure Checking Gil Mainifold??? >
Old 07-02-2006 | 01:56 PM
GOODT's Avatar
Default Re: HELP!!! Pressure Checking Gil Mainifold???
usualy but not always
GOODT is offline
Old 07-02-2006 | 10:22 PM
Ok I pressured up the manifolds, one held constant the other however did not even hold any. I will pull it to inspect tommorrow. Do you think that I should replace both manifolds or all four And if so what would you recomend?
Rcolter is offline
Old 07-03-2006 | 06:18 AM
Payton's Avatar
Charter Member #927
Most recomend replacment. If you run in Salt it is only a matter of time.
I had a leak right at the top of the devider between runners. I had mine TIG welded 2 years ago. and it is fine. My manifolds had run in salt, I run in fresh.
Payton is offline
Old 07-03-2006 | 08:22 AM
How old are your manifolds? Mine are 10yrs old if they are original, andhave been run in the salt.
Rcolter is offline
Old 07-03-2006 | 06:03 PM
Payton's Avatar
Charter Member #927
I'm not sure on the age. They were used when I bought them. At 10 years old I would think they need checked very carefully or replaced.
Payton is offline
jeff1000man
4
03-24-2007 05:51 PM
Enticer Rick
2
09-21-2006 10:30 AM
mtgbiker
34
06-15-2006 08:39 AM
formula31
3
01-12-2003 08:23 PM
hauling ass-a
2
07-23-2002 10:12 PM
