Oil Presure Problem >
Oil Presure Problem
Oil Presure Problem
Old 07-06-2006 | 08:59 PM
GOODT's Avatar
Default Re: Oil Presure Problem
youll get pressure but not very much
GOODT is offline
Old 07-06-2006 | 09:08 PM
Why is that? I have a priming tool and hefty drill. Would it have enough presure to indicate on a mechanical gage. My starboard engine did, but I want to make sure that I am not chaing a ghost.
Also, I am afraid to start the engine without oil pressure. Thanks for the help
OhioRiverCigarett is offline
Old 07-06-2006 | 10:51 PM
Pwrbt33's Avatar
OK, do not start the engine. Put a good mechanical gauge back on the engine and prime it with the drill again. Didnt know if liked taking the distributor in and out so many times. Keep in mind it may also be like the other person stated, oil galley plugs may have been left out. I think you would still have pressure at the main cap at the rear, but we will see.
John S.
Pwrbt33 is offline
Old 07-07-2006 | 04:19 AM
im starting a pool..... ive got 20 bucks that says its the galley plugs
stevesxm is offline
Old 07-07-2006 | 06:46 AM
Pwrbt33's Avatar
Well, lets think about this for a second or two. Even if the oil galley plugs are out, they are above the oil pump and rear main cap. Where are there plugs: The back of the block above the cam- oil would be leaking out into the bilge. Front of the block above the cam- The lifters aren't moving so the chance of oil even getting there are slim to none. If its a GenV,VI or VII and the lifter valley plugs were left out again the lifters are not moving hense no oil to the top of the engine.You might have a little from the mains feeding the cam bearings but very little with a drill. When that oil pump is spinning it should be moving oil to the mains and the oiling system. The engine usually has to be in motion for the lifters and valve train to get lubrication. The 2 oil galleys we are refuring to should have pressure even if the other galley plugs are out, the only differance would be is the rest of the engine above those plugs wouldn't recieve enough if any oil for lubrication.
We dont live in a perfect world and ANYTHING as we all know is possible! Especially trying to fix something over the phone or internet with out seeing it for yourself!
John S.
Pwrbt33 is offline
Old 07-07-2006 | 04:47 PM
Question Re: Oil Presure Problem
I know remote diagnostic are near impossible. I appreciate everyone help. I have never had to fight a no oil pressure problem in any engine that I have built . I have had low oil pressure because of old mains, but this is the first no oil pressure. To further complicate that it have flow (and a lot at that) but still no pressure. I am going to try to see if the bypass is stuck using air pressure as you suggested.
Dinner then an short evening project. Thanks again to all for the help. I am trying all I can not to pull the engine. I will update.
Old 07-08-2006 | 06:21 AM
Remove spark plugs and have an assistant roll over the engine via the prop or prop nut jammed against another. Do this while priming with the drill. Use a 2K rpm drill. Look for oil off the rocker tips and keep an eye on the gauge. You should hear and feel the drill slow down when you get pressure.
BadDog is offline
Old 07-10-2006 | 05:42 PM
I was unable to unstick the bypass or it wasn't stuck. I am going to check for oil plugs. Are we talking about the plugs under the timing cover? Are there any others I should look at? Thanks
Old 07-10-2006 | 08:37 PM
I think the plugs they are refering to are under the intake manifold by the lifters. If these are removed you will have no pressure.
jeffswav is offline
JeffC
06-13-2006 11:17 AM
speed demon
5
06-26-2005 07:08 PM
cig1988
9
05-07-2004 05:45 AM
olysan
8
02-24-2003 07:00 PM
