-   -   Knock modules on Carb 305's (https://www.offshoreonly.com/forums/general-q/134820-knock-modules-carb-305s.html)
txriverrat2001 07-10-2006 02:08 PM
OK - Got one that will not go full timing at first - baby the throttle and it'll finally go full advance and run up. Disconnected the knock sensor - still same thing. I don't do a lot of work on small blocks, especially carb motors with knock modules - so any advice would be greatly appreciated. Is it common if a knock module is failing to only increase the timing in steps - say every 4 seconds or so? Anyone that's worked this scenario would be familiar - so give me your 2 cents!
rs
GOODT 07-10-2006 02:41 PM
Re: Knock modules on Carb 305's
year and model
txriverrat2001 07-11-2006 11:40 AM
1998 305 2bbl
GOODT 07-11-2006 12:23 PM
1 Attachment(s)
see if this helps
